adventureman5's avatar
May 01, 2022
AC Quits Blowing Cold after a few minutes
My AC Won't keep blowing cold on my 2006 RV E-450 gas. I just replaced the
high and low cut-off switches and when I put the pressure gauge on the AC, it
said that everything was running perfect and it was running cold too. But then
let it run for ten minutes and it stops blowing cold and now the pressure gauge
reads above the high area into the yellow and headed towards red (too much
pressure) and I can no longer hear the compressor kicking on and off. I actually
let out some of the freon, since the gauge now read too high. But this has
been a cat and mouse game for some time. We changed out the relays and
that didn't help. It's blowing fine, there doesn't appear to be any vacuum
leaks, as I've read about those (and it was running fine going up hills prior to
this). Right now it's just sitting flat on my property and not even working the
engine. No blockages. But it makes travel in summer months pretty awful. Any
ideas?
