FIRE_UP
Jul 24, 2013Explorer
hotjag1,
Well Sir, this may be caused by the infamous "sending unit" located in the lower thermostat housing. As has been stated, a secondary push on the stop switch should reveal a secondary code. If, you push it and, it flashes three times, then a short pause, then three more flashes then, a long pause and then, it repeats the sequence all over again, that's what's known as code "33".
And to many of us, it means an "Over heat condition". The causes are:
1. Clogged cooling air intake (leaves, debris, etc)
2. Low coolant
3. blocked or clogged exit for the cooling air
and more.
But, quite often, it's not any of those causes. Quite often, it's corroded probe, on the end of that sensor. You see, that little sensor, is about the size and shape of a spark plug. And the sensor probe, which is very close to the size of 14MM spark plug threads, resides in a very tight, bore in that housing. But, what commonly happens is, even though your coolant can be clean and green, that probe has very little coolant flow around it due to the proximity closeness to the bore, and it starts to get corroded and, it will do it to the point that, the corrosion will seal the cavity between the probe and the housing.
When this happens, the probe starts sending incorrect signals to the generator ECM. One of the incorrect signals is "An over heated condition" and, the engine is then shut down to protect itself even though the coolant is not hot, and, you have none of the other causes either.
So, what's the answer here? Well, if you're capable and willing, the gen may have to be slid out, if you're one of those fortunate to have slide out Gen, or, it will have to be removed from the bottom and then get at that sensor which, can in many cases, be one serious pain in the a$$. Good luck.
Scott
2. Low coolant
and more.
Scott
38,780 PostsLatest Activity: Aug 05, 2026
