kidkasha's avatar
kidkasha
Generator Regulator LPG Fleetwood Discover 6500 onan
I am told that the Generator for 6500 onan Regulator LPG 1999 Fleetwood Discovery is needed.How expense is it to get it installed, and what do twheusually cost.
  • The generator will need to be removed/top accessed to replace/overhaul the regulator.
    Overhaul kits ARE available, though not from Onan. The regulator is a standard regulator, but if overhauling it, you need to make sure to spec the high-heat/silicone gasket kit.
    No idea how much labor-- depends on what is involved in getting to the regulator.
    Yes, I have overhauled the regulator on one of these. Not complex once generator out and accessible. Regulator overhaul itself did not take 10 minutes once out.
  • Onan does not have generator regulator for my 6500 generator and none are available
  • In CA shops charge for 1 hr minimum, usually at $150 rate.
  • If you need the main propane regulator (on the tank) it's available.
    Camco 2 stage horizontal regulator
    Looks like $22 for the regulator. Replaced mine without any hassle. It's about a ten minute job so even a shop charge should not be that much.
    Prior MH had the Onan 6500 LP genny. Only concern is the vent should face down, look at how yours is mounted.
    enblethen has info on the generator mounted regulator above..
  • About 1 hour.
    I would check around with your local propane dealer. Regulator could be the same for other LPG rigs such as fork lifts.
  • How much do you think it cost to install the regulator
