txnese wrote:
So the generator died, I took off the fuel line, pushed the primer, and no fuel and no sound from pump. I decided to replace the fuel pump and filter. I pushed the primer to confirm pump is running and look for leaks, good there. Now when I try to start the generator , it sounds like it’s hydro locked. Or won’t crank and got 3 flashing lights. Blown generator starter fuse? Did I prime too long?
About 30 minutes later. I decided to take out the spark plug, no fuel on the plug. I put it back in and the starter worked and generator cranks up and now i'm just waiting to see if it dies. Running out of time today, so will update after next big trip.
I believe the 3 flashes is telling you it has stored a fault code. If you press the stop button three times within 5 seconds. it will again flash three times. Press the stop button one more time and it will flash the fault code. It will be a single flash or more followed a few seconds later by more flashes. It will repeat this code. There could be more than one fault code and it will flash any additional code the same way.
