Chrave
Aug 03, 2021Explorer
Generator switch
I’m having a problem I hope some one out there can help with. My Onan 6000 quiet diesel generator won’t start unless the ignition key is in the running or accessory position. I could run an always ho...
Chrave wrote:
The 2 coach batteres are new. 700 cca each and 12.6 volts at check. But the corrosion is a possibility. Thanks for the tip
