Is there a problem running your generator when plugged into shore power. I have my RV plugged into shore power and would like to run the generator, is this a problem. I just like to run the generato...
Why would you want to do that? I assume so you don't have to unplug to exercise the Gen?? If you really want to exercise the gen it should be under a decent load which won't happen if you are plugged in. It will just idle. You need to load the gen which means letting it power your coach.
Modern transfer switches are designed to mitigate a problem but I wouldn't tempt fate. The result could be really bad and expensive and not really get the results you want anyway.
