Is there a problem running your generator when plugged into shore power. I have my RV plugged into shore power and would like to run the generator, is this a problem. I just like to run the generato...
Like someone else mentioned, its sooo easy to flip the shore power breaker to off. And yes to the person who asked if you can exercise the gen set while going down the road. Just turn your roof airs on while doing so to put a load on the gen set. If its cold outside, use the heat strip setting or reverse cycle heat setting if you have them. Hot water heater set to electric works too but be sure there is water in it (not winterized).
