I have used my generator intermittently a lot in the past couple of years, but next week, I will need to use it for about 65 -70 hours, non-stop. I know generators are made to be used, but I just want...
What generator do you have? I would hesitate to subject a cheap HF unit to that kind of use. Other than going through a lot of fuel you should be alright although you may get tired of listening to it. Change the oil before you go and check the level each time you refill the tank or every five hours or so. DO NOT refuel with the unit running.
