Gia, Drew, Phil, Am I correct thinking all of you, myself as well, have 4KW ONAN generators in the "4KY" Series?
Phil, Please post the specifics of the oil you've chosen for your generator and application. I'm not trying to start an oil debate. LORD Knows there are plenty of them. Just thinking the 10W-40 Valvoline Dino that's in ours now probably isn't the best choice I could make. You think things through and I'd like hear your pick.
For 4KY Owners Everywhere: ONAN builds good equipment. The small engine many think of when they think ONAN is a two cylinder horizontally opposed pressure lubricated engine that runs at 1800 RPM in RV Generator applications. It has low oil pressure protection built in, and might (haven't researched this) also low oil level protection. TMI? Read on. 4KY has a single cylinder, splash lubricated engine that runs at 3600 RPM. It cannot have oil PRESSURE protection due to being splash lubed. No oil pump and that's why 4KY doesn't have an oil filter. Early 4KY's had low oil LEVEL protection but it was deleted years ago. I understand it had so many false positives (shutting down when level was OK) that most 4KY's now in use never had the low level feature.
What all this has to do "with the price of eggs" is that we can run a 4KY till it dies of oil starvation and never know it unless we check the oil level regularly. Generator level, engine stopped, with the dipstick part of the filler cap. The "price" in all this is that a few years ago, several OP's right here at RV.net lost the engines in their 4KY's because they hadn't kept up on checking the oil and keeping them full. I have the carburetor off one that failed in a horse trailer and scrapped after engine ran low on oil. So I check the oil in ours way more often than the limited use it has (400-some hours on the counter and most of current use is exercise).
So Gia, for you... My suggestion is start with a full crankcase of oil that isn't many hours or many seasons old. Have a quart or two of oil with you and check it after say 8-12 hours. If you didn't have to add oil, check it at least daily. I don't think there'll be a problem, but if there is, the downside cost is too high to ignore. You belt in and buckle up on the road. Do the same thing for your generator partner.
