gsf35099
Jul 06, 2014Explorer
Generator voltage drop.
Hi gang,
I've got a Guardian QDP75 generator that is dropping volts and squealing when a heavy load is on. Pretty sure it's the drive belt slipping & I have a new one for replacement.
Has anyone had a problem with the barring going out on the tensioner? Wondering if I should get a replacement for that as well or just try the belt first.
I found a post on another site where someone had the exact same problem & said spraying belt spray on it made the problem go away. Assuming that was only temporary.
Thanks for any advice.
