- tiffy2000ExplorerThis is more about the electronics of the genset but good engine no-start troubleshooting here also , scroll down a couple of pages
https://www.flightsystems.com/pdf/onan-rv-troubleshooting-guide.pdf
Norm - Passin_ThruExplorerDOHH??? What is that? DUH spells DUH; DUH!
DOH a female deer? - AlaskaShooterExplorerMy propane Onan is notorious for not starting after sitting. We have mud wasps that love the smell of propane and they go up a black rubber vent house and deposit mud and clog it. I have to then use a coat hanger to snake out the crud and clear the line and it fires right up till the next time. To fight this I put a golf tee in the line which works great till the next time you go to use it and it won't start cause the line is plugged with a golf tee. DOHHHH, made me laugh. But easier to fix.
- MahakalExplorerThanks Everyone. Will definitely look into the suggestions.
- Bionic_ManExplorerWhat fuel does it use? If it is LP, you need to check those tanks as well.
In addition, my generator has a couple of fuses on the front. I had one blow and it would not start either. - atsrmfExplorerMy Onan needed a fuel pump, circuit board, and a carb rebuild. I did the work myself and now it runs great. The difference is mine hadn't been started since 2000.
- MahakalExplorerI must have started in december. i think
- Isaac-1Explorer IIHow long has it been since you last started it?
- gboppExplorerYou need at least 1/4 tank of fuel for the generator to operate. That's assumining the generator is fed from the chassis tank. Have you replaced the gen fuel filter lately?
The filter may be attached to the bottom of the carburetor.
Let us know if a low fuel level caused the problem. - MahakalExplorerI definitely Check the tank in the morning. Thank you
38,778 PostsLatest Activity: Jun 10, 2026
