B_B's avatar
B_B
Generator
Getting ready to do oil and coolant change on a quiet diesel generator. Unit stops every now and then, has anyone installed gauges for the oil pressure and coolant temperature? May change the belt while I am working on the unit.
  • B&B wrote:
    The generator is the HDKAJ 7500, I HAVE the manual, just wanted to know if anyone had installed gauges. Thanks for the reminder about how to replace coolant.
    my bad - i should have stuck to your original question (and not keyed so much off a responders comments).
    having just installed a EC-30w i cant imagine going with any solution other than onan....it was more expensive than some alternative but it was completely plug & play (didn't take me 30 minutes).
    google is showing the gauge package as low as 198 bucks for the 300-5027
    I wish a similar solution was available for my 10kw
  • The generator is the HDKAJ 7500, I HAVE the manual, just wanted to know if anyone had installed gauges. Thanks for the reminder about how to replace coolant.
  • you don't say what model you have -
    I too would like to add some gauges to mine....onan makes a set for the 6k, 7.5k & 8k - p/n 300–5218 or 300–5027.
    you should be able to find the model manuals on-line pretty easily.
    if you have a 10k/12.5k let me know - ill send you the file.
  • If your unit is an Onan Quiet Diesel, read the manual before you drain the coolant. There is supposedly a specific procedure for adding the replacement coolant to insure it is filled properly and completely.
