rmgeorgiaExplorerSep 08, 2021generatormy kohler generator tries to start on its own checked the switch works fine not sure if it is a control board problem or not?
6 RepliesReplies sorted by NewestLouLawrenceExplorer IISep 13, 2021dodge guy wrote:Let us know if it has an auto start feature.^^^^^^^^^^^This before anything else^^^^^^^^^^^^^dodge_guyExplorer IISep 13, 2021Let us know if it has an auto start feature.way2rollTrailblazerSep 13, 2021Newbie hit and run post.ronbielExplorerSep 12, 2021If your generator is not equipped with auto start, it could be a wiring-related issue.bgumExplorerSep 08, 2021You need to get with Gjac above his Kohler won't start at all and you can't keep yours from starting.way2rollTrailblazerSep 08, 2021Welcome to the forum. Need more information. Is this in a motorhome, if so what year, make model, etc. Is there an auto start on the genset? It could be self starting for low batts, program temp sensor in the HVAC etc.
Related ContentGenerator noise reductionGenerator operationGenerator questionBest generatorGenerator will not run installed
