BrocNeal
Jul 15, 2020Explorer
ron.dittmer wrote:BrocNeal wrote:So there is one 12V item that works regardless of your power source. That puts an interesting spin on your situation.
So I just tested the water pump and it does work in all cases as it should. But still no lights. What does that lead you to believe?
It sounds like you have checked or traced wiring that you are able to, checked fuses, replaced faulty circuit breakers, and here you are with this weird electrical situation.
I wonder if something disconnected behind your 12V fuse panel. Is that panel independent, or integrated into a converter or other devise?
ADDING: Oh, I see others here have offered the same advise.
I'm honestly not sure, there is a box under the hood that seems to tie into the fuse box and also ties into the house battery. I believe it's the inverter but I'm not 100% positive.
38,767 PostsLatest Activity: Jun 10, 2019
