whemme
Jul 20, 2020Explorer II
BrocNeal,
Things to check now that you have the service manual to reference.
1) Using a voltmeter against ground, check the voltage on the blue wire going to the battery charger board when either plugged into shoreline power or with generator running. If it reads around +16 vdc or so that is good showing that the dc output from the transformer module is good.
2) Then check for dc voltage on the two orange wires going to the Auto Breaker. You should have around +14 vdc on both orange leads. If no dc voltage on either orange lead, then the battery charger pc board is bad an must be replaced, If dc voltage exists on one orange lead but not the other, than the Auto Breaker is open and must be replaced.
38,767 PostsLatest Activity: Jun 10, 2019
