Chum lee wrote:
When I bought my used 99 F53 Class A in 2011, the previous owner let the generator, a 4k gas Onan, sit for almost a year in Mesa, Arizona. The generator would start, but ran like ****, then it would die. With coaxing, it would eventually run, but, it would surge with changes in load. The now previous owner agreed to pay and have a mobile RV tech look at it. The tech said the carburetor was all gummed up. He replaced it with a new carb. +-$700 later and it was purring like new again. The generator then had +-300 hours on it. Now it's over 1,800. Just my experience.
Chum lee
yup it happens. I think evaporation of the fuel plays a large part. Dittmers carb may not totally evaporate siting in a garage in cool climate. A year in AZ sun, different story.
Another true story, Just visited one of our sons buddies at his grandparents cabin after snowmobiling. Grandpa has a stable full of sleds and not a lot of mech knowledge (after talking with him for a while). Just burned a cylinder in one of his sleds, first ride of the year, at the end of the day after riding all day.
1. He used yellow bottle HEEt in the tank, cause he thought there was water in tank? (Before the ride). Yellow bottle is death to high performance 2 strokes. Methanol not good.
2. The gas in that sled and every sled in his shop was yellow and smelled like c rap!
He said all was gas from last year, pump premium, not non ethanol. (But ethanol in gas basically eliminates slugs of water because it absorbs the water, like isopropyl and methanol, which is what red and yellow bottle HEEt is).
Can't say for sure, because I'm not tearing his engine down and fixing it, but the likelihood of the methanol or a partially plugged carb causing it to run lean are the 2 most likely causes of the failure. Could have a plugged or cracked oil injection line to that cyl as well that caused it, but far less likely.
The moral of the story is gas does go bad and it does screw up engines regardless of what some folks experience or luck lets them beleive.
4 strokes are more tolerant of bad fuel, especially low performance engines like generators and your average car/truck engine.
