dougrainer wrote:
B.B.Upch wrote:
So my onan 7000 marquis runs great until I try to put it under a load & then it bogs down. & eventually dies. It's bogs down to the point Tha it will not run my a/c but for just a second. I put new oil filter & oil (it is level) & new fuel & air filter on it. Tried cleaning the carb by running fuel & b12 in a gallon can thru it but still no change. Also cleaned the rings & still the same thing. I'm thinking of replacing the fuel pump next but it is the expensive 149-2267 on it now. Cam I replace it with the cheaper smaller one & mount it somewhere else? What else do you suggest?
How did you clean the "Rings". Never heard of that. WHY would you think changing the Oil/filters would fix this type problem? It will not. Bogging down is NOT a fuel starvation problem in the sense you think it is. You do not state how many hours, but have you changed the 2 spark plugs? This is not your problem but they probably need changing. Your problem is fuel starvation. It is a CARB problem. The jets in the Carb are clogged and the mixture and possibly the Governor system is out of adjustment. Running fuel system cleaner will NOT clear up the 16 jet holes. It only takes a few holes to be clogged or partially clogged to cause performance problems. The ONLY fix is to either take the carb apart and remove the jet and clean out manually or buy a new carb. Onan does NOT make a carb rebuild kit, but you can disassemble the bowl and access the jet and remove it and reuse the existing O ring and gasket. typical fuel pump problems will cause slight surging and then it just dies instead of bogging down. Doug
PS, aftermarket Fuel pumps LOOK the same but have a HIGHER psi rating than what Onan's require.
He just MIGHT be referring to the slip rings on the generator rotor.
