LaPalmaMama
May 13, 2013Explorer
Genset issue
Gen is shutting itself down. It worked fine for a trip and then upon returning home it shuts down after running a couple minutes it shuts down and blinks a code 12 that reads:
"Inverter overvoltage fault
(controller not able to regulate to rated voltage)
Corrective Action: Check weather the vehicle engine and genset share teh same starting battery. If so, and this fault action occurs when cranking the vehicle engine, low battery voltage may be causing this shutdown. Increase teh battery capacity or install a separate battery and battery charging system for the genset."
Can this be explained in lamans terms for this mom? Do I need to take it in or is there a simple fix? I don't know why anything would be overloaded when nothing is plugged in or running.
Thanks
Thanks
