bluwtr49
Oct 04, 2013Explorer II
You shouldn't have any problem if you keep the inside of the coach at normal living temps using whatever you have for a heat source. If your water tank is full or nearly so there is to much volume to freeze in a single temp excursion to only 24 and the water lines probably run either at floor level or inside the coach. Enough heat will radiate through the floor to keep things OK. Plus your HW heater will also help the bays.
38,766 PostsLatest Activity: Jan 10, 2026
