mowermech
Apr 19, 2015Explorer II
Your best bet is to find an RV that meets your needs that already is set up with the propane/electric frig. I rarely see an RV with a residential frig. I know they build them, I simply have not seen one very often.
That is just as well, because I don't want one.
But to directly answer your question, yes, it can be done. The only problem you might encounter is if the rig was built around a residential unit, it might not have the gas line and/or 12 VDC installed, and that could be a problem to install. Not impossible, but perhaps difficult.
Of course, if you move up to a NEW rig, you can specify what you want.
38,782 PostsLatest Activity: Sep 02, 2026
