tropical36
Apr 19, 2015Explorer II
MrWizard wrote:
to the OP
if your intent on an RV absorption fridge, then buy an RV with one already installed
try to get the TWO door smaller 7.5cuft fridge that is NOT a fire hazard
its the four door, french door side by side (1200) that has the most problems
very likely the the RV with residential fridge from the factory, does not even have a LP line to that location, making the change, a labor expensive change over
I thought it was the other way around and our Dometic side by side wasn't part of the fire prevention recall, but the top and bottom models were. Maybe you're talking about another brand, such as Norcold and think I've heard more cons for them, than Dometic, but then again, I'm most sure it was the older units.
38,782 PostsLatest Activity: Sep 02, 2026
