Licreek wrote:
Good morning, I have a couple final comments about my ground fault issue. I bypassed the gfi and all is working fine. Now for my last question. I just bought a Hughes Autoformers and this is the first time iv used it. What it does is monitor the line voltage into the rig. When I plug in my voltage to meter into an outlet I notice the voltage is changing from 123 to 126 volts. Could that change in voltage cause the gfi to trip? Thanks, Lee
Glad the perseverance paid off that's how I work also The hughes sounds like it working fine and should not be effecting any GFI
however still need to figure out the gfi reason for tripping
you as suggested by another here may have mixed up the load wires when u put in new one there the direct load wire and line load so u need to know what the supply black wire is(from breaker) and the other one feeds downstream outlets same with white neutral
Bishops deal is a great post showing the systems
