gutfelt wrote:
Executive wrote:
Licreek wrote:
Good morning, I have a couple final comments about my ground fault issue. I bypassed the gfi and all is working fine. Now for my last question. I just bought a Hughes Autoformers and this is the first time iv used it. What it does is monitor the line voltage into the rig. When I plug in my voltage to meter into an outlet I notice the voltage is changing from 123 to 126 volts. Could that change in voltage cause the gfi to trip? Thanks, Lee
Apparently you either didn't read my post or you don't care about safety. That said, the Hughes will not cause a ground fault. You have a GROUND FAULT somewhere in your circuitry. Bypassing the GFCI only gives you a feel good situation and the DANGER is still present...you just don't know it. Sooner or later you'll find it..your rig will catch on fire (unlikely) or most likely you'll touch the wrong part and fry your hair. Then you'll have a come to Jesus moment where you'll say, maybe I should have done some more checking.
Simply put...you have a ground fault in your system. You replaced the GFCI and the new one still trips. That means the ground fault was not in the switch. It's in ONE of your receptacles. FIND IT AND FIX IT!
instead of acting holier than thou and chastising maybe read and comprehend the OP questions and whats hes doing
maybe help him solve his problem not berate him continually
he simply bypassed the GFI to determine if he had a dead short verses a bad gfi or a GFI interference
That's what he did he has full intention of reinstalling the GFI once he determines the fault;; he as some others here(ME) like to figure things out on their own as most of do, some are lazy and call a repair guy ;;each one to their own
either help in the resolve or butt out in my opinion
Gutfelt, Executive is a very well respected long-term member here and you are chastising him.
He can have an opinion too just as you can. Quit acting like you are the moderator. You have only been a member for not even two months.
You seem so quick to jump on people.
MM.
