IF you're gonna upgrade, then go ahead and do so. But, instead of a small upgrade, look at something that's a little higher level than what you're looking at. You're basically going from one manufacturer's entry level to another manufacturer's entry level. This change does not make sense IMO. Plus you are going backward in year of manufacture. I would look at a slightly older, but higher level coach to replace your present entry level coach. I would look in the 2006 to 2009 range and see all the very nice coaches available that will give you much more than you presently have. This is just my opinion.
