Going north there is only one almost steep section early on and then a few rolling hills. 55 max and right two lane restriction when towing in CA. Just hang with the truckers.
The decent has a truck speed limit of 45 or is it 35? Does not apply to you however you will be on your brakes. Anyway just go slow on this section. Coast up to maybe 55/60 and then brake moderately firm down to maybe 40 and let it coast back up again. Repeat until you are down. Pull the lever to hold a lower gear and keep your rpm 3000 to 4500 for engine braking. Some gear should allow your speed and rpm to stay close to these ranges.
Don't ride the brakes to maintain a steady speed.
