OFDPOS's avatar
OFDPOS
Going Price For An Alignment ?
So what's the going price for an alignment ?
I know when the word "MH" comes into the equation for some reason the $$ signs get higher..
Got the New to me 05 FW 5000. 25 ft with 29K on the OD.
The old tires were some off brand name, they had a kinda choppy wear pattern if that makes since , not worn on the sides, middle or ? just had the choppy wear like it bounced down the road wear.
(saw that on alot of the used MH's we looked at)...
I put on new Bilsteins shocks front and rear, new Michelin's all the way around. Called the local place here that has a nice following of customers and they were recommended by alot of people.
I go in for my scheduled appointment, he writes me up for $80.00
I'm ok with that. He drives it around starts to pull it inside and it won't fit inside their shop overhead lights etc too low.
Backs it out , says sorry can't do it.
I call up the next place on the list witch was rec. and over the phone its $150 for starters I'm told :E No going into detail after I ask what all is done , just $150 and we go from there... I didn't like his tone saying "and we go from there"!
I kindly reply back thank you and end phone call.
I then call up a place where I used to live close in Redding Ca. Talked to the guy there and he quotes $115 for a standard alignment which includes what they use to call a thrust alignment where as not only are they checking the front out ,they also check the rear end as well to make sure its running true with the front end.
So curious to know what others have paid or quoted ?
