TNGW1500SE
Jul 26, 2016Explorer
korbe wrote:TNGW1500SE wrote:DSDP Don wrote:
I do this routinely. It floods the black tank with grey water which is good for cleaning and lubrication. For those of us who use a SaniCon Macerator, we can do this every time we dump without removing/lifting the hose. When boon docking, we can also flow grey water into the black tank when the grey water is getting full.
If you want to do what you're doing without lifting your hose in the air, buy one of these. Drain Valve
I don't have room for another valve. Wish I did.
The valve looks like it has the standard half turn connection, just like your clear fitting. Sounds like you could attach it to that clear fitting and just connect it with all the other fittings when you dump.
I have to put the clear fitting on the sewer end of the hose. The outlet on the RV angles down to a hole in the compartment and there's just not enough room for a valve. If there was, I'd install a third valve.
