DSDP_Don
Jul 31, 2016Explorer
"TNGW1500SE".....One thing that was never mentioned and some people don't know.....you're 3" drain, where you connect the sewer hose is designed to rotate. Typically, it's rotated down so that the hose can be brought up through the bottom of the water bay. You can rotate it up, install the drain, (it has bayonet fittings) and come out your bay door with your hose when doing a final drain.
You can also add a clear extension to it and then attach it to your drain. There are many ways to get one to fit. You just need to take a good look.
