On the snoreing thing, if you have sleep apena, you probably will swear that you do not snore, while others say you do. Believe it or not, you can't hear yourself snore, because you are asleep!! The point to say is that sleep apnea is a SERIOUS problem, and can cause you to die, or get you killed if you fall asleep at the wrong time. Please do not ignore this, and if others say you snore, believe them!! Solutions are simple, and can save your and others life. BTW, I can and will sit up outside all night if I want to. Quite hours mean quite, not locked inside!
