Semi Retired Grandpa wrote:
Led astray numerous times by our current GPS navigator. Replace every couple of years. Time for another. Cabela's has the Garmin nuvi 2557LMT for $129.99. The Garmin nuvi 65LM for 119.99. The Garmin 55LM for $89.99. Looked at the Garmin website and see numerous models (our current model is from a different manufacturer BTW). Which would you recommend and why?
I'm curious as to how the GPS led you astray. if the maps aren't kept up to date then the possibility of errors increase. no different than using a 10-yr old paper road atlas. if that's your issue you may find that updating the map on your current GPS may be less expensive than buying a new platform. if you do buy new be sure to keep the maps up to date.
