Anyone stay at the National Park campground on the North Rim? I noted almost all sites have a max of 27' length. Is this a factual number or sufficient safety factor for say a 30'er?
The golden Aspens are a sight to behold in the fall. The Lodge and services close on the North Rim sometime in Oct if I remember right. We were there just before closing. Snow had chased us South from Bryce Canyon that week.
The North rim is really cold right now, and under about 3-6 feet of snow. The North rim closes due to snow by November, opens around May 1, give or take a few weeks due to snow coverage. . .
I parked a 37' Montana there. Be careful walking around at night until you know the layout. I almost walked over the rim of a side canyon that was right behind my space. There were no guard rails and it was very dark. I should have had a flashlight but I only walked about 30'. We had pulled in right at dusk. Otherwise, I like the north rim better than the south. North is cooler and green. South is hot and desert.
I was there in September, and saw quite a few larger than 30'. Most/all spaces are semi-circular pull-thru spurs off the roads, left and right sides. The one cautionary factor is that there can be trees when you pull in and/or pull out, and you have to watch carefully entering/leaving.
