Tvov
Jun 10, 2016Explorer II
kidkasha wrote:
I often wonder is dumping Grey Water permitted in campsites, if so where. I have never done it but I am curios
I assume you mean at a campsite without a grey water drain?
Because there are many campgrounds in New England where they have grey water drains at each campsite. These are simply white PVC pipe in the ground that lead to a gravel filled hole in the ground. Usually the PVC pipe is too small a diameter to match a stinky slinky, but easy to use with a garden hose for draining grey water. Combined with having water at the campsite, very convenient as you can then take nice showers without worrying about over filling your grey tank.
Otherwise, ASK at whatever campground you are at. Just because you see someone else doing it doesn't mean it is allowed.
I agree with those who say they don't want to set up a TT in a spot where the previous camper drained their grey water - even if it was "just dripping".
