epennal
Aug 20, 2015Explorer
Grey water tank won't drain completely
New RVer here. My Grey water tank will only empty down to the 2/3rd level. Not completely clogged, obviously, but why would it stop draining at that point? I don't think it's a sensor issue because...
- Aug 20, 2015This is what I would do if I wanted to check how much water it takes to fill up the grey tank:
- Drain grey water tank until no water comes out of sewer outlet
- Close grey water valve
- Get a bucket with a known fill mark, say 3 gallons
- Fill bucket to 3 gallon mark and pour down your shower drain
- Repeat as many times as it takes until shower starts to back up
- If it took 10 buckets, then you have 30 gallons capacity
- If it takes, say, 5 buckets until full, 15 gallons, then ya probably got a problem
I am assuming your grey tank should hold at least 30 gallons, BTW.
