NC_Roamer
Oct 19, 2014Explorer
tom311 wrote:
n c roamer,when you say it leaked in hard rain doesn't that damage the finish and or cause a mold issue?and logan I am in ohio so Indiana would be good idea.just wondering if no slide is better,,but would like to feel comfortable with no issues.
The leak was along the vertical rear gasket where the slide closes against the motorhome wall. The small amount of water, maybe 2 fluid ounces, ran down the outside of the rear slide wall which is not wood. It puddled on the vinyl flooring where it was wiped up easily without any damage. The leak never got onto any wood or carpet or behind any wall where it could not be blotted up. If it had to leak, it was not a bad place.
