Is there an adapter or connector that can be attached to my main propane tank so I can connect our grill without carrying additional 20 lb. tanks? I already have a hose extension. Chuck
Thanks all. This will connect to the built in tank under my motorhome so anything designed to attach yto a standard propane tank isn't going to work. The grill arrived today so I can check to see if it's high or low pressure. This is the grill, http://www.amazon.com/gp/product/B0009V1BDA?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 . BTW, It is designed for the small bottles and I have the adapter on an extension hose. So I suspect it's low pressure. Chuck
