Is there an adapter or connector that can be attached to my main propane tank so I can connect our grill without carrying additional 20 lb. tanks? I already have a hose extension. Chuck
I think all Coleman grills are high pressure. You cannot remove the regulator and covert it to a low pressure grill because they use their own proprietary threads. The Weber Q grills are adaptable with the right fittings. To use a Coleman grill you must tap into the gas line at the tank outlet, but before the regulator. Camping World sells Low Pressure grills.
