wny_pat1
Aug 08, 2013Explorer II
WyoTraveler wrote:And Camco product can be purchased at most any RV store. And if you are near a propane distributor, they should be able to set up up cheaper! One thing to remember, if your grill has a regulator, you want your connection at the tank to be before the tanks regulator. But if the grill doesn't have one, you want it to be after the tank's regulator.
Camco sells the valve and hose. The quick connect hose is 10 ft. The valve replaces the one on you bar b q if it doesn' have the quick disconnect connector. Runs about $55 at Amazon. The camco catalog can be downloaded on line.
