Rich_D_
Aug 09, 2013Explorer
gonefishin77 wrote:
Finally got the pictures to post
Thanks for the tips so far
Can't tell from the photos whether the connection is high pressure (tapped before the regulator) or low pressure (tapped after the regulator). If it is high pressure, you MUST install a regulator at the outlet and remove the one on the grill if present. Not doing so would allow the entire hose length to be filled with high pressure propane. Disconnecting the hose with the rapid discharge of propane could "burn" (freeze) any skin that came in contact. Also there is a high chance of explosion if a source of ignition is nearby.
That said, they make a quick connect female with a positive shutoff. If the shutoff/connection you have is not that type have a professional install one on your tank and install the male end on a regulator attached to the tank end of your hose. I have had two coaches set up that way with a slide out gas grill. Works great. Shutting off the source while the grill is still running burns off the small amount of low pressure propane left in the hose. Sure, this can be done with a hose filled with high pressure propane but it will take a very long time and forgetting to do it could prove catastrophic.
