ron.dittmer wrote:
timmac wrote:
Well just checked my 08 Bounder wall specs and it to is mounted on the outside on a wall hanger, after 12 years and 52,000 miles its still in great shape and zero issues, Fleetwood says its to reduce squeaks from the wall to floor.
That makes no sense to me, but it must be working because many manufactures do it. It is good to read that you have no issues.
BTW: Our Phoenix Cruiser 2350 with the walls resting on the floor, is 13 years old and we have no squeaks either. It's been a very "tight" rig. I imagine it helps that the house is smaller than most in over-all height and width. Any box made with the same exact materials will be stronger when made smaller. A softer riding suspension should also help.
I am not sure why some mount the wall on outside vs on the floor, maybe to make the rv wider inside without making the floor and frame under floor wider to save money..
As to Fleetwood saying so the floor wont squeak on wall if mounted outside I would have to say everything else squeaks and rattles so I don't really know..
