hohenwald48 wrote:
msturtz wrote:
. . . the Class A has a 208” wheelbase and a 55 degree wheel cut the Class A is much more maneuverable. Add to the fact that the class A has a short 3” front overhang and a short 3’ rear overhang. . .
Something doesn't compute. A 413" long motorhome on a 208" wheelbase has to have 205" (17+ feet) of overhang somewhere. If it has 3" on the front and 36" on the rear, where'd the other 166" (13+ feet) go? Maybe I'm just reading things wrong. Wouldn't be the first time. :)
It's a bit more complicated than that. Our DP has about a 48" front overhang when measured to the centerline of the axle but the salesperson measured it from the front of the tire. So, 208" + 48" + 2x 36" (22.5" wheels are actually larger than 3') is about 328" back. This leaves about 86" or 7' of rear overhang compared to the over 12' of rear overhang on our Class C. It depends on where you measure from and to however in every case a DP is going to have a relatively shorter rear overhang as a percentage for a given length than a Class C. We had a Class C rig with an OEM listed length of 31' and an actual length of 33.5' and a 45 degree wheel cut compared with our Class A DP which has only a 208" wheelbase and a 55 degree wheel cut a much larger (compared to the C) front overhang and a much smaller rear overhang again compared to the C.
