I need help. I have been pulling a small 20 ft TT and have finally decided to upgrade to motorhomes. I read a ton of stuff here,looked at many and decided a small (26-30) ft class A or C would be best...
Carry a tire gauge that will accurately read up to 80 psi when you take a test drive. The first and cheapest thing in driving issues is tire pressure. You won't go far wrong by setting the tires' cold pressure to what's on the door post. Over inflation to the '80 psi' on the sidewall, especially the front tires, can have a bad impact on driveability.
