I need help. I have been pulling a small 20 ft TT and have finally decided to upgrade to motorhomes. I read a ton of stuff here,looked at many and decided a small (26-30) ft class A or C would be best...
I added Hellwig sway bars front and rear and saw huge improvements. Our chassis is older than yours but the rear sway bars are the same. Wanted to let you know that although the 2008+ chassis uses a different Hellwig part number, the 2007- bar will also mount. Buying new, you'd want the part specified for the late model chassis, but if a used older one showed up, you'd be able to use it.
