I need help. I have been pulling a small 20 ft TT and have finally decided to upgrade to motorhomes. I read a ton of stuff here,looked at many and decided a small (26-30) ft class A or C would be best...
j-d - Your answer sounds accurate. One thing to mention is that the frame stretching was probably done in accordance with Ford's standard. The problem could be it does not apply to what is built on that chassis behind the rear axle. The frame stretching typically is between the axles.
