JaxDad wrote:
Vibrant93 wrote:
Max PSI rating is 110psi on this tire. I cannot find anything on Hankooks site about weight to pressure ratings. Figures I'd ask here.
Thanks guys!
Inside the drivers door is a label attached by Winnie (Itasca) that gives you the tire inflation pressure needed.
Unless you’re packing everything you own, that pressure will be just fine.
You are correct. It is located there, but mine is just wrong wrong wrong. Mine shows 70 psi on an "F" rated tire. At that inflation, it is totally under inflated. Had mine weighed and needed more air. Also, my label says "F" 12ply tires, but Winnie had equipped it already with "G" 14. Called Winnie about all this and they had no explanation, but did agree about the air pressure was too low on the label. Bottom line is: Know Your Weight
