Vibrant93 wrote:
Just wondering if anyone on here is running this tire? I just had a set of (6) 245/70r 19.5's put on my 2000 36' Itasca Suncruiser and was wondering what everyone was running for tire pressure? I had Goodyear's on the coach prior to these Hankook's and had a drive tire blowout last season. They were an F rated tire. The new Hankook's are a G rated 14 ply. The shop I had do the mount and balance had them set at 70psi when I picked the coach up. Personally I thought that might be a little low but I didn't really question it which was probably my fault. After a 30 mile drive home I checked pressure again and we were at 80psi on all of the tires. Max PSI rating is 110psi on this tire. I cannot find anything on Hankooks site about weight to pressure ratings. Figures I'd ask here.
Thanks guys!
It's imperative that you first weigh each axle and then add 10 - 15psi to the cold pressure ratings on the inflation chart and available for download....
HEREAmbient temp. has nothing to do with cold psi ratings and the extra cushion I recommended, should take care of these changes along with other variables one will encounter.
