timmac
Jan 27, 2014Explorer
427435 wrote:
The ride is probably being hurt by the H rating. I hope you are running the pressure at what you actually need and not at the max pressure on the side wall of those H tires.
The recommended pressure for a 20,500 lb GVWR should be around 80 psi with 245-70/19.5 tires.
I have played with the pressure from 80lbs to 100lbs, still rides bad, however the higher pressure the rv is more stable but the humming noise is more high pitch, going have all new Hankooks installed today, will report back the quality of Hankook tires.
38,782 PostsLatest Activity: Sep 01, 2026
