Extremist
May 20, 2014Explorer
derh2o wrote:
Question--how do you wax underneath the cab overhang? Specifically, in the center.
I use an "idiot stick". A sanding pole that painters/tapers use for ceilings. I have used a swifter in the past with microfiber rags mounted on it (the rubber holes will hold) but found the stick wasn't sturdy enough.
Just have to be careful the pole doesn't flip on you - happens when actually using it for sanding once in awhile.
38,707 PostsLatest Activity: Jan 05, 2014
