memtb
Apr 16, 2018Explorer
“IF” it is a Ford chassis, and “IF” Ford is still using the older model front suspension design....it is likely that you need “much” more caster put into the front end alignment. This has been (for many years) an ongoing problem with the Ford E 350’s and 450’s. With factory spec “caster “ the unit has “very” nervous or twitchy handling characteristics. It can/will work the driver, trying to keep it from wandering all over. Do some research on what others ( including myself) have done to mitigate this condition. If memory serves me correctly...I think that 5 or more degrees positive caster is required to help the situation! Ours is much better....but it ain’t no Mustang GT!
38,778 PostsLatest Activity: Jun 06, 2026
