DrewE
Apr 16, 2018Explorer III
What has been said is true; definitely check the tire pressures and weights and consider having the caster checked.
There should not be noticeable play in the steering, which would feel like bumps back and forth as the road conditions change. If there is, you probably have some worn tie rod ends or something along those lines that should be taken care of. I would not expect that on a 2018 with 12K miles, though; it's barely time enough for their first drink of grease.
38,778 PostsLatest Activity: Jun 06, 2026
