youracman
Oct 17, 2018Explorer
ron.dittmer wrote:DrewE wrote:Just FYI to the readers.......
There are no drums on the E-SuperDuty chassis (which was renamed to the E450 a year or two later). It's disc brakes all around, with the parking brake being mounted on the drive shaft in a little housing bolted to the back of the transmission.
My brother has a 1997 E350-V10 (not a Super Duty) motor home with rear drum brakes and a cabled parking brake to them.
I own a 2007 Super Duty E350-V10 motor home with rear disk brakes and a cabled parking brake to them.
The drive shaft parking brake you mention is on the E450 up to and including year 2007. Every year of the E350 to this very day, never had the drive shaft parking brake. The drive shaft parking brake was discontinued starting with year 2008.
Thanks for posting, Ron. Good to know. My 2007 (2006 chassis) has the driveline brake of course and I wish it had the cable system. No problems with it at all, but if/when that driveline unit fails it is sure expen$ive to replace. I believe the main reason for failure is overheating....usually from forgetting to release the parking brake. Fortunately, mine has a loud beeper with different sound than normal to slap me alongside the head when the brake is left on. I may have driven it 100 ft or so that way a couple of times. :^(
I also have read that starting in 2008 the brakes were bigger. I'd sure like that...if for nothing more than to dissipate the heat better (and a bit more stopping power would be welcome too.) Hmmm maybe I need to update to a 2009 rig....or not.
Safe travesls ..............
38,766 PostsLatest Activity: Jan 29, 2026
